01-26-2024
12:50 PM
12:54 PM
I've set up my TR8620a on my MacBook Pro running osMAC Sonoma, however, I've been unable to print with it over AirPrint which is the only way this model prints over the network as far as I know. When I look at System Settings -> Printers & Scanners, I see the printer and the little green circle next to it and the word Idle.
However, when I print, I'm told the printer is offline. I removed the printer from that machine and tried to set it up on two different MacBook Pros that we have in the household and the results are always the same.
In trying to research the problem, I read somewhere that if using AirPrint I shouldn't use the install software but just set the printer up on the network. I'd like to give that a try, but first I would need to uninstall the software the install disk put on my computer.
Can anyone tell me where to find all those files so I can move them to the trash and try to print that way?
TIA
02-06-2024 01:12 PM
Go into the library folder of your MacOS and select printers. From there you will be able to remove any Canon drivers or software you installed.
02-06-2024 01:12 PM
02-06-2024 04:34 PM
Thanks so much. That was a great help.
