PIXMA MX922 intel vs silicon chip question
YumYum
Im currently using an Apple M3 Max based MacBook Pro on Tahoe 26.5. Lately ive started getting some pop up messages that soon Intel based programs will not be supported. I do have Windows for Mac and I know I will eventually have to upgrade that. I also looked in my system info for my Canon Pixma and saw this:
I use the Canon IJ Scan Utility daily and am wondering if when the change is mad by Apple, will I no longer be able to use it?  Do I need a silicon version?  Also, what are there so many Canon IJScanner showing??  Tks!
11 REPLIES 11
MattKauf
I have exactly the same question YumYum with an additional couple.  The IJ Scan utility is used to start and coordinate the scanning process and that seems to be the thing that won't work after OS27 comes into play.  Searching on the Canon Site, there seems t be no reference to their decision to update their App to a Universal/Apple Silicon.  That popup you AND I are getting is a message from Apple telling us to go to Canon to get the update-of which there is none.  I'm not sure if the scanner will be recognized either, but I am guessing that it will be but will have to be operated through ScanTools or something like that.
Canon does mention a Lite version of the IJ Scan Utility but then says it's not compatible with the printer/scanner/FAX we both use.
It's a shame that Canon seems not be be supportive of their products.  I just seems like the smart thing to do, since I will never buy another Canon product if they desert us like this, would be to make their Lite software, which I think I saw WAS Apple Silicon compatible, able to talk to and control THEIR older All-in-one devices.
Hopefully, someone will read this and figure out how to help thousands of owners of Canon devices and newer Apple computers.
Good luck to us all,
Matt
YumYum
Yes, lets hope. Tks.
jrhoffman75
Any item identified as "Universal" is compatible with Apple Silicon.
Thank you. But i also need to print and print utility reads intel and i see no mac version. And why are there so many IJ scanners listed?  I have only 1 app installed.
Anonymous
Not applicable
Reasons for Multiple Canon IJ Scanners in Mac System Info
When using a Canon printer with scanning capabilities on a Mac, you may notice multiple entries for Canon IJ scanners in your system information. This can occur due to several reasons:
Connection Protocols
  • AirPrint vs. Canon-Specific Drivers: Your Canon printer may be detected as both an AirPrint device and a Canon-specific device. This happens when the printer is connected via different protocols, leading to multiple listings.
Multiple Additions
  • Re-adding the Printer: If the printer has been added multiple times under different settings or configurations, it can result in several entries appearing in the system information.
Network Configuration
  • Network Settings: If your printer is connected to the network and has a static IP address, it may show up in different ways depending on how it is accessed (e.g., via IP address or Bonjour).
Troubleshooting Steps
IF you want to reduce the number of entries:
  1. Remove Duplicates: Go to System Preferences > Printers & Scanners and remove any duplicate entries.
  2. Re-add the Printer: After removing, re-add the printer using the preferred method (AirPrint or Canon-specific).
  3. Check for Updates: Ensure that your printer drivers and macOS are up to date to avoid compatibility issues.
so I have printer installed as airport and canon version. Just not sure why so many scanners listed for only 2 protocols.  Mine is the Wm printer for me and the other is on my wife's Mac.  Screenshot 2026-05-15 at 17.40.06.pngScreenshot 2026-05-15 at 17.40.06.pngScreenshot 2026-05-15 at 17.40.19.pngScreenshot 2026-05-15 at 17.40.19.png
Anonymous
Not applicable
If any print command does not get confused and try to pick a printer that isn't there, I don't think the duplicates are causing an issue, am I correct?
No issues yet. Just wondering.
why so many and why do i have intel stuff on mac. Printer programs usually also take up a lot of space too. Duplication = wasted space?
Anonymous
Not applicable
PCs don't usually install two complete copies of the same print program.
