07-19-2023 09:02 PM
I recently purchased the ImageClass MF269dw II. I need to be able to print over AirPrint from my phone. I can do this when the machine is awake, but it doesn't show up as active or as an available AirPrint printer when it's asleep. When I wake the machine up, it immediately appears as an AirPrint destination. I connected the printer to my Eero WiFi network. I turned off the power save on the network connection. It's connected via DHCP, but I previously tried a static IP address. Neither one worked when the Canon was asleep.
I also have a Brother color laser that always appears on my network as an AirPrint destination. It's just the new Canon that needs to be awake to print. I also noticed on my Mac that the Canon printer shows as offline, but I can still print to it. I don't have these problems with my Brother printer. I'm disappointed in the Canon but hope to find a solution.
07-20-2023 08:13 AM
I have a Pixma Pro-100 connected via Wi-Fi. It also needs to be powered on for the printer to be recognized. The printer has a power-off timer setting in the driver, but specifically states that printer will remain always on when connected via Wi-Fi. That appears to be the Canon design basis.
07-20-2023 09:00 AM
Greetings ,
Has John pointed out he might be able to make changes to the printer's power management settings and for keep alive or awake.
I would also try assigning the printer a static or reserved IP on my network. This can be done on your wireless router. It only has to be done once.
07-20-2023 09:25 AM
I am using a static/reserved IP, but it still isn't visible while the machine is asleep. The max I can keep the printer awake for is 60 mins, but that is wasting energy. When in Energy Saver mode, it's like it doesn't exist. I don't get it. If this is a feature, I'm returning the printer as soon as possible. It's not functioning the way my Brother printer does. I need to be able to print without waking it.
