08-03-2015 04:18 PM
I have a MF4570dn, and recently upgraded from Windows 8.1 to Windows 10.
I can no longer scan using the MF Toolbox utility. I had MF Toolbox 4.9 installed before the upgrade, and it worked just fine. After the upgrade, I get "Cannot communicate with the scanner" error dialog:
I thought I would try to reinstall the MF Toolbox utility, but there are two problems.
1) The downloads page shows no downloads for Windows 10 for this printer. This should be updated.
2) I downloaded the one for Windows 8.1, and tried to reinstall, but it just hangs at the "Processing Installation" screen:
I've also tried to uninstall the existing MF Toolbox first, and it also hangs at this same dialog.
I've also tried various other things without success:
- Connecting via USB instead of Network. It detects the scanner, and MF Toolbox can switch to that device, but it still gives a communications error.
- Trying the built-in Windows Scan app instead of MF Toolbox. It uses the WIA driver. It barely starts to scan, then immediately cancels.
Please Canon - forward this to your engineers and provide a fix asap. I cannot use my scanner on Windows 10.
(I can use the printer functionality just fine.)
01-11-2016 07:51 AM - edited 01-11-2016 09:25 AM
Thanks Piers_A, I can use scanner.
But still is nor perfect because when i finished scan, I can not switch from SCAN to FAX or COPY on my printer, when I use cancel, nothing happend, on windows 7 after I finished scan switch work.
Problem with MFT I have on computer, where I install upgrade from windows 7, another computer with clear instalation Windows 10 MFT work.
Canon i-SENSYS MF8380Cdw
01-14-2016 10:16 PM
This remains a MAJOR problem for thousands of users. Canon PLEASE correct this problem with the MF Toolbox scanning function and Windows 10.
01-15-2016 01:35 PM
THANK YOU!
01-17-2016 12:04 AM
Thank you so much for your solution. It works immediately! To think I almost uninstalled / re-installed, bought new software etc.
You saved me a lot of needless aggravation.
01-17-2016 04:12 AM
Do we know if this is a Canon problem or a Microsoft problem?
01-17-2016 09:06 AM
"Do we know if this is a Canon problem or a Microsoft problem?"
My Canon MP640 color inkjet stopped functioning after a major Windows 10 update.
At the same time, a new app appeared in the MSFT app store that restored full function.
It would seem that either MSFT or Cannon could do the same for my MF4150 by creating a new app to restore full functionality.
01-18-2016 02:40 AM
I add exactly the same problem on my side.
Canon, help !
P
@mj1856 wrote:I have a MF4570dn, and recently upgraded from Windows 8.1 to Windows 10.
01-20-2016 06:47 PM
I have the same problem like PhilLeBon.
Everything was working while on Win7-64-bit.
Now MF Toolbox utility Scanning does't work after Microsoft upgraded my Win7 to Win10.
I cannot uninstall MF Toolbox 4.9 either. It stucks PhilLeBon.
I think many people have this same issue.
Canon please help us.
01-20-2016 06:57 PM
01-20-2016 07:12 PM
That very sad dcp. I would hate to go back to Win7 from Win10. As I understand... Canon needs to fix this issue to support
latest OS of Win10.
