MF Toolbox doesn't work on Windows 10
mj1856
I have a MF4570dn, and recently upgraded from Windows 8.1 to Windows 10.
I can no longer scan using the MF Toolbox utility.   I had MF Toolbox 4.9 installed before the upgrade, and it worked just fine.  After the upgrade, I get "Cannot communicate with the scanner" error dialog:
I thought I would try to reinstall the MF Toolbox utility, but there are two problems.
1) The downloads page shows no downloads for Windows 10 for this printer. This should be updated.
2) I downloaded the one for Windows 8.1, and tried to reinstall, but it just hangs at the "Processing Installation" screen:
I've also tried to uninstall the existing MF Toolbox first, and it also hangs at this same dialog.
I've also tried various other things without success:
- Connecting via USB instead of Network.  It detects the scanner, and MF Toolbox can switch to that device, but it still gives a communications error.
- Trying the built-in Windows Scan app instead of MF Toolbox.  It uses the WIA driver.  It barely starts to scan, then immediately cancels.
Please Canon - forward this to your engineers and provide a fix asap.  I cannot use my scanner on Windows 10.
(I can use the printer functionality just fine.)
435 REPLIES 435
Hi Reba.
Thank you for your response.
To verify if another program may be causing a conflict with the MF Toolbox installation, please place the computer in 'Selective Start Up' mode, and then try the installation again. To place the computer in this mode, please follow the instructions below:
1. Press the Windows key and 'x'.
2. Select 'Run'.
3. In the Run window type: Msconfig
4. Select OK. If the UAC window opens, type in your password and select OK.
5. In the System Properties screen, choose 'Selective Start Up'.
6. Uncheck the box labeled 'Load Start Up Items'.
7. Click Apply.
8. Under the Services Tab, click on 'Hide all Microsoft Services' at the bottom of the window just above the OK button.
9. Click 'Disable All'.
10. Click Apply.
11. Click Close.
12. Restart the computer.
After reinstalling the MF Toolbox please return the computer to the 'Normal Start Up' mode by following steps 1- 5 from above. However, this time, select 'Normal Start Up' in Step 5. Next, click apply, and then restart the computer.
If you are still unable to reinstall the MF Toolbox, it is recommended that you call us at 1-800-OK-CANON (1-800-652-2666) for further assistance.
ruki
I have a MF4550d, and recently upgraded from Windows 8.1 to Windows 10.
Please can you provide a fix.
ruki
I can no longer scan using the MF Toolbox utility.   I had MF Toolbox 4.9 installed before the upgrade, and it worked just fine.  After the upgrade, I get "Cannot communicate with the scanner" error dialog.
This is what worked for our office full of computers when we also got the "cannot communicate" error.
Click the search/cortana button in the taskbar, search for "services" (also found in the administrative tools in the control panel) right click on the "Windows Image Aquisition" and click properties, click on the log on tab, and change it to local system account and check the box to allow it to interact with desktop service.
cdlots
7/23/16 Fix that worked for me on Win 10, dl patch from Canon site for my printer, ran the patch, reboot, the scanner now works. Yeah.
This worked for me too!!  Finally!!
Let's hope it doesn't break after my next Windows update......
previously, i had installed the latest SW and driver, changed the WIA service (steps below), and it fixed the scan issue but i couldn't initiate the scan via the start button on the imageclass (4370dn).
i haven't done 'extensive' testing but the NetworkUSBScanPatchEN.exe patch from 7/7/2016 appears to have fixed the scan issue on imageclass (4370dn) and i can initiate the scan via start button on the imageclass as well.
in particular, i recall that if you scan, disconnect computer from imageclass, power off imageclass, power on imageclass, reconnect computer to imageclass, then scan again it wouldn't work.  now it does.
i listed steps that i recommend for updating SW and drivers as well.  i'll respond back if i run into issues.  but i have a feeling canon finally (a year later) resolved this issue.
steps for changing WIA service (in case the NetworkUSBScanPatchEN.exe patch doesn't fix your scan issue):
  1. Select Start
  2. Enter services.msc
  3. Select the Services Desktop App
    1. Scroll down to Windows Image Acquisition (WIA)
    2. Right-Click Windows Image Acquisition (WIA) and select Properties
      1. Select the General tab
        1. Make sure that the Startup Type is set to Automatic
      2. Select the Log On tab
        1. Select the box next to Local System account
        2. Select the box next to Allow service to interact with desktop
      3. Select the Recovery tab
        1. Select the First Failure drop-down
        2. Select Restart the Service
        3. Repeat for Second Failure and Third Failure
        4. Leave Reset Service After set to 1 minutes
        5. Select the box next to Enable actions for stops with errors
      4. Select Apply then OK
  4. Reboot
steps i recommend to update SW and drivers:
reboot
uninstall mf###-###
reboot
uninstall canon mf toolbox ####.mf##
reboot
install mf####-###
reboot
reboot
Respected Sir or Madam,
I tried ti reinstall MFTOOLBOX with the disk I had recd with my CAnonm Printer mf4320.But while scanning i getr an Error msg. cannot communoicate with printer. it may be disconnected edtc,
Kindly do the needfukl and guide me.
Thank You & Warm Regards,
GANESH SUVARNA
@hagaih wrote:
Same here.
I got the MF4890dw all in one.
Toolbox not working after upgrade to Win10.
Canon - a response on this thread would be nice.
GANESH SUVARNA
@hagaih wrote:
Same here.
@hagaih wrote:
Same here.
@hagaih wrote:
Same here.
@hagaih wrote:
Same here.
GANESH SUVARNA
Friends and Family
