07-25-2024 05:38 PM
I verified the IP connection to ensure that did not change. I just bought and set up this printer. I set a UI code. I did connect over the network wirelessly to the printer from my Windows 11 laptop. I was able to see the interface. Today, I decided that I did not want like the UI pass code and wanted to change it. I was not able to find clear instructions on how to do this. I don't believe I ever had an "administrative" option on my printer control panel.
I'm not sure what I did, but now when I try to access the user interface on my laptop by specifying "http://my canon printer ip address", I get the following message:
Cannot access Remote UI.
Configure a [Remote UI Access PIN], or a [System Manager ID] and [System Manager PIN] on the device.
To remove the UI code, the instruction manual indicates that I should press a symbol -- I can't figure what the symbol is nor do I find anything like it on my printer control screen. Like I mentioned, I don't see any "admin" choices on my printer control panel.
I have no access to the Remote User Interface now. I did not knowingly delete the UI passkey that I originally set.
Where do I go from here?
07-25-2024 09:09 PM
When possible, can you please provide reference to the part of the manual where is states "to remove the UI code press symbol"
Canon - imageCLASS MF465dw / MF462dw - User's Guide (Product Manual)
Once the Remote UI code is set, it cannot be changed or removed unless you log into Remote UI.
To reset the printer, please see the following:
If you do have a Remote UI PIN set and do not know the PIN, you will need to contact Canon Support.
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8
~CarePaks Are Worth It
