MAXIFY MB2320 Can't Change the Wireless LAN Setting
sunshine1
Printer Series: MB2320
I can't change my wireless Lan setting and can't print from the computer. Error message says " Cannot change the setting. If the device is in via the LAN, finish it and then change the setting." In adddition, when I try to print it on computer it say "Another computer is using the printer." PLEASE... HElP.
2 REPLIES 2
jrhoffman75
Assuming that no other computer is connected I would recommend you delete printer driver an restart the installation process. That worked for me when I ran into installation/connection issue.
I know this is a super old thread but I found the answer to this problem on a TS8200 today.  All you need to do is reset the LAN settings under Device Settings.  Fixed it immediately.  Im not sure if this will apply to old models of printers but worked for me.
