ImageCLASS MF753Cdw refuses to connect to computer via Wi-Fi
NMAster
Everything I try to scan from the printer onto the computer it prompts 'connect to computer' yet the printer itself is connected to my windows 10 pro computer. I cannot access MF scan utility because it claims that the driver is not installed. I have installed both the printer driver and the scanner driver on multiple attempts yet nothing has changed. I have been fighting with this scanner for over a month since it has arrived. There is nothing on the internet or even the canon website regarding the specific problem I seem to be having. I feel I have tried almost everything and am frustrated with how useless even the Setup guide that came with the printer completely ignored the setting up of the scanner portion of the printer. I just need this problem remedied.
25 REPLIES 25
Moderator
Moderator
Thanks for joining the conversation, NMAster!
So that the Community can help you better, please let us know whether your printer communicates with your computer via Wi-Fi or via a USB cable. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
rafcaf1975
I would like to by pass the network and have my computer talk with the printer.
rafcaf1975
I have the Color imageclass 753cdw.
Hi Danny,
My printer connects to the computer via Wi-Fi. Yet the scanner portion of the printer refuses to connect to the computer even thought the printer part of the printer works fine.
Bonzo22
Have you found a fix?  I have the exact same problem for 5 weeks now.  Frustrating in the least as I need this for my office and son's paperwork.  I've tried everything from up to reinstallation, including connect to direct computer and via wi-fi.  Is there a Patch I'm unaware of?
Sorry, no we have not found a fix. Canon help is very unhelpful. There used to be a youtube video about it but i was taken down way before i even encountered the problem for the first time. I have been dealing with this for almost 2 months.
Bonzo22
I am sorry to hear that. Funny thing with mine is that the scanner worked for 3 months prior to it not working. I only used it once or twice a week but needed it for multiple tasks. This is my first Laser Printer and love the speed and its quietness for home use. If this doesn’t get resolved soon I will have to buy a competitors unit that works.
I was using an A to A cable with male ends. I just ordered an A to B cable and see if that makes a difference. The wi-fi connection to my PC is useless, even with a strong signal.
Update:  I swapped my A to A double male end USB cable for a A to B USB Cable, installed on Win10 pc, left unplugged from the printer and powered off, loaded Driver MF750CMFDriverV7501W64, connected the printer when prompted and powered on.  I waited about a minute and scanned to my pc.
My scanner is working both Color and B&W.
I hope this helps others having issues.
This is the cable I ordered from Amazon. JSAUX Printer Cable, 10FT USB Printer Cable USB 2.0 Type A Male to B Male Scanner Cord USB B Cable High Speed for HP, Canon, Epson, Dell, Brother, Lexmark, Xerox, Samsung etc and Piano, DAC
[Link replaced with screengrab to facilitate discussion]
