02-13-2025
03:57 PM
04:36 PM
Tiffany
I'm looking for a simple B&W printer with USB connection only. The Canon Image Class D570 Monochrome Laser Printer with Scanner & Copier, connects with either USB or Ethernet. Question: Can anyone walk me through the process of "dis-connecting" the printer's ability to connect to WiFi??? The printer will only be used through the USB connection to a desktop by a child that is sensitive to WiFi. I've turned the WiFi connection off before on HP printers, and would like to think (hope?) it's also possible on Canon.
02-13-2025 04:39 PM
Welcome to the forum!
So that the Community can help you better, let us know which version of Windows or macOS you are using? Any other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
02-13-2025 05:07 PM
Thanks for your reply Tiffany. I'm using Windows 11, but in my experience, the means to cut ties with wireless was through the printer's touch-screen. I'm familiar with how this works on an HP printer, but would like to try a Canon printer...............if I can shut the wireless capabilities down. Even though I'll be working off the USB port -- the machine will constantly be sending out wireless signals unless I can turn it off.
