04-20-2015 12:41 PM
I own a Canon MX452 and a MacBook Pro (2010 model). This week I updated the MacBook operating system to Yosemite 10.10.3. Afterwards I found the printer / scanner functions would not work. I re-loaded the CD from the printer and was also prompted to download more currrent drivers from the Canon website, from which I chose the ICA Driver V4.0.0 and the Canon IJ Network Tool V4.5.0 (not sure if these were the right ones or not).
I managed to only get the printer working when using the USB cable to the printer. I could not get the printer and scanner working wirelessly. The printer blue light shows it is connected to my network ok. I also noted my iPad and iPhone can no longer "see" the printer either.
I have deleted and re-loaded the Canon software several times. I have followed Canon instructions to:
-Connect the MacBook to the router with an ethernet cable and go through the instructions to "connect" the Canon MX452. But afterwards, the MacBook says the Canon MX452 is "off line" and I can only make it work with the USB connection.
Any guidance would me most appreciated to:
-get the printer and scanner working wirelessly
-getting the Air-Print feature working with the iPad and iPhone
Thanks
Stephen
04-20-2015 07:37 PM
Hi John
Five trys later, I finally got it figured out. Many thanks for the link you provided. It helped me through the iterations until I finally got it
Best wishes
Stephen
04-20-2015 01:40 PM - edited 04-20-2015 01:42 PM
I think the blue light just means that printer wifi is enabled; not that it is connected. airprint won't work until the printer is on the network (and same network as iPad). Do these instructions help:
04-20-2015 03:44 PM
04-20-2015 04:21 PM
04-20-2015 07:37 PM
Hi John
Best wishes
Stephen
