12-24-2021 06:14 AM - edited 12-24-2021 09:24 AM
Hi. I just got a new SSD for my computer as the last one died. I tried to install the Canon MF217w with the drivers on the Canon website. The first being this => UFR II Printer Driver - V21.20, Fax Driver - V10.10 (MF217w/MF216n), ScanGear - V11.3, I followed the instructions, left the printer unplugged from the computer until done installing the driver. I am using Windows 10 and the printer is ImageClass MF217w. I'm sure of the MAC and build.
I restarted the computer and installed the patch.
I restarted the computer again to make sure and checked my programs list. I do not see the tool kit listed to make scans or prints.
Listed items under Canon in my programs list is:
Fax readme
MF drivers readme
MF220_MF210 series manual
ScanGear readme
Toner status
Ufrii LT Readme
UFRII lT XPS readme
Can someone help me to get the toolkit back and start using this MF printer, please?
Thank you.
12-26-2021 06:19 PM
I solved the problem.
I went to the website I originally went to https://canoncanada.custhelp.com/app/browse/a_status/published/channelRecordID/DRIVERS_AND_SOFTWARE/...
Installed the following for Win 10 (x64) into the program files x86 folder (not sure this helped but it worked this way)
Drivers:
1) Driver Version : UFR II Printer Driver - V21.20, Fax Driver - V10.10 (MF217w/MF216n), ScanGear - V11.3
Software:
1) [Windows 32bit & 64bit] AddressBook Tool Ver.1.1.5.2
2) [Windows 32bit & 64bit] Tool Box Ver.4.9.1.1.mff18
3) Toner Status Version 2.1.0
Everything seemed to install fine now and the Printer is recognized now.
12-24-2021 09:19 AM
Greetings,]
Can you help us out and tell us what OS you are using the printer with?
Windows, MAC... version and build?
~R5 C (1.1.2.1), ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw MF656Cdw ~Pixel 10 ~CarePaks Are Worth It
12-24-2021 09:22 AM - edited 12-24-2021 09:23 AM
12-24-2021 11:41 AM - edited 12-24-2021 11:47 AM
I was asking Windows or Mac operating system 😆
You are Windows 10, the feature build is less important, but if you want to know yours, press the start menu button and type winver (then press enter).
Downloads for your device are here:
Support | Black and White laser | imageCLASS MF217w | Canon USA
Make sure windows 10 is selected in the drop down box.
@dmega wrote:The first being this => UFR II Printer Driver - V21.20, Fax Driver - V10.10 (MF217w/MF216n), ScanGear - V11.3
This part is concerning.
The UFR Driver I see available for your printer and W10 appears to be v7.1.2
Just wondering where you are downloading from? I would use the package installer above. It includes everything you'll need for Print/Scan/Fax
12-24-2021 11:50 AM
Thanks I will go to your link to run the drivers.
FYI I got my drivers from here ==> https://canoncanada.custhelp.com/app/browse/a_status/published/channelRecordID/DRIVERS_AND_SOFTWARE/...
12-24-2021 12:19 PM
I installed the driver, the toolkit restarted the computer. The toolbox was "not connected to a scanner". But my MF217w is connected to the computer with USB cable. I downloaded the patch and executed it. Tried the toolbox again and it still says
" A supported scanner is not installed. Please install a supported scanner, and then restart toolbox".
Under Printers and scanners the canon MF210 series is listed
12-26-2021 04:52 AM
I tried to install all of these drivers/patches/software but always the printer is not recognized.
UFR II/UFRII LT V4 Printer Driver V7.1.2
[Windows 64bit] imageCLASS MF217w/MF216n/MF212w MFDrivers (UFR II / FAX / ScanGear)
[Windows 32-bit & 64-bit] Patch for Network Scan, USB Scan
[Windows 32bit & 64bit] Tool Box Ver.4.9.1.1.mf18
12-26-2021 01:30 PM
Hi. I uninstalled all canon drivers and software. Restarted the computer then tried to install the v7.1.2 driver. I select USB connection and that were the install hangs. I then get this message:
I follow the instructions and keep getting this message.
12-26-2021 06:19 PM
Drivers:
Software:
