How to setup 2 TS3522 identical printers in different locations?
OldChick
Have 2 TS3522 printers in 2 different locations. Is there a trick to get them set up correctly? Thanks
4 REPLIES 4
Moderator
Moderator
Thanks for joining the conversation, OldChick!
So that the Community can help you better, please let us know if these two printers will be part of a network. It would also help us to know exactly which operating system is running on the computers involved (i.e. Windows or macOS, and which version thereof) and how they're talking to each other (i.e. via Wi-Fi or a USB cable). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
The only "tricks" I might suggest are giving each a static or reserved IP address and using unique names.  This will help you differentiate between them.
Example:
"Home TS_3522"
"Office TS_3522"
Danny- Thanks for suggestions!  They will be in 2 separate locations with 2 separate networks, but using 1 laptop computer which travels with us. We run Windows 10 OS and they set up will use wi-fi for communicating. Hope this helps for some suggestions. Thanks!
Thanks for suggestions.
