06-12-2015 07:37 AM
How do I remove Canon " My Image Garden" from the desktop when turning on my computer ? I have the icon but the program starts up and I have to delete it manually from the desktop to clear my screen for other work...
10-30-2021 07:53 PM - edited 11-01-2021 06:38 PM
to remove from desk top, delete shortcut
to stop it from starting up with use of the scanner...
I have a MG7720
open IJ scan Utility
open settings in the left low corner of the IJ scan Utility window
go to every option and chose to send to a windows folder instead of myimage garden
I'm sure there is a format for it but canon won't share
I just made sure that my imagegarden was not any option
prevents myimagetorture from opening and sends scanned images to a windows folder for trouble free use
disappointed in this printer, can't handle odd size papers and envelopes, jams more than my previous pixma, takes forever to get ready to print... and, poor instruction...
should be easy to answer a queston like this
I was laughing a couple years ago when website challanges meant it took me 25 minutes to order cartridges and then, the order wouldn't process because canon was out of the "free photo paper" I didn't want or need...
and, there was no option to decline it
and, when I spoke to canon reps, they couldn't understand why I found that to be a problem or, why I was not willing to wait on hold for 40 minutes to order cartridges as I did the time before...
good for a laugh but not for customer service
01-23-2023 02:17 PM - edited 01-23-2023 02:17 PM
In Windows, press Ctrl-Alt-Delete. Select Task Manager. Select the Startup tab. Look for Canon Quick Menu. Select it and click the Disable button at the bottom. It should change from Enabled to Disabled.
This does not uninstall the Quick Menu. No need to. You can open it from the Start Menu when you want to use it. It just won't start automatically when Windows opens.
