12-29-2022 06:28 PM
Title says it all. I've tried manual connect and entering the network SSID manually, but no dice. The AP is about a meter away, and it's got the lower speed network fine.
Separate question: how do you enter capital letters and numbers using the keypad? pressing 2 four times to cycle it to capitals only takes it back to lower case (a-b-c-a). It's a mystery!
Thanks,
12-29-2022 07:04 PM
The G7020 has a 2.4Ghz radio and is only capable of connecting to a 2.4Ghz broadcast. It will not connect to a 5G network.
12-29-2022 06:46 PM - edited 12-29-2022 06:50 PM
Are you sure 5G is enabled on your wifi router? Do you see your 5G network from a computer?
Do you know the name of your 5G network?
12-29-2022 07:04 PM
12-30-2022 12:07 AM
Thanks both. 1) Yes, the 5ghz network is up and used by many devices in the home.
2) Well crap. I read its spec to say it supported 802.11 b/g/n and ... well, n uses both speeds. What a disappointment. My old TS8300 runs on 5gHz and that's years old and cheaper. Nice new one is gimped? Disappointing.
Thank you for the helps all the same!
