G7020 doesn't identify 5gHz networks, only 2.4
atapi
Title says it all.  I've tried manual connect and entering the network SSID manually, but no dice.  The AP is about a meter away, and it's got the lower speed network fine.
Separate question: how do you enter capital letters and numbers using the keypad?  pressing 2 four times to cycle it to capitals only takes it back to lower case (a-b-c-a).  It's a mystery!
Thanks,
The G7020 has a 2.4Ghz radio and is only capable of connecting to a 2.4Ghz broadcast.  It will not connect to a 5G network.
3 REPLIES 3
normadel
Are you sure 5G is enabled on your wifi router?  Do you see your 5G network from a computer?
Do you know the name of your 5G network?
Thanks both.  1) Yes, the 5ghz network is up and used by many devices in the home.
2) Well crap.  I read its spec to say it supported 802.11 b/g/n and ... well, n uses both speeds.  What a disappointment.  My old TS8300 runs on 5gHz and that's years old and cheaper.  Nice new one is gimped?  Disappointing.
Thank you for the helps all the same!
