G3202 Not being detected in Wifi Setup
DeviantWolf
Just got a new G3202 printer and i follow both the setup instructions in the manual and with the software but the printer is not getting detected during the setup. Any advice would be appreciated.
1 REPLY 1
The first thing to do is confirm the device is indeed connected to your WiFi.
Following the steps below:
Canon Knowledge Base - Easy Wireless Setup for Windows - PIXMA G3200
The printer will only connect to a 2.4Ghz broadcast, so if your router is using SMART connect or similar (One SSID for both broadcasts) you might need to temorarily disable this feature during the printer's installation.
