Duplex Scanning option not available in MF Scan Utility anymore - MF656Cdw
ElPabloMaximo
So, something has happened and I can no longer perform duplex ADF scanning using the MF Scan Utility more. This HAS been working for years. I CAN do it from the printer console if I want to walk a back and fourth with a USB stick, but not using the utility. The software seems to only recognize the device having single sided scan capability.
I have
  • Updated firmware
  • Ensured latest drivers
  • Ensured latest version of MF Scan Utility
I don't seem to be able to find an older version of the utility to see if it is some kind of regression issue.
7 REPLIES 7
Moderator
Moderator
Thanks for joining the conversation, ElPabloMaximo!
So that the Community can help you better, we need to know exactly which operating system is running on your computer (i.e. Windows or macOS, and which version thereof). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
ElPabloMaximo
Edition Windows 11 Home
Version 24H2
Installed on ‎11/‎4/‎2024
OS build 26100.3194
Experience Windows Feature Experience Pack 1000.26100.48.0
ElPabloMaximo
So, no one has any ideas why the device is suddenly only detected as being capable of simplex scanning after being a duplex scanner for 2 years?
I can assure you the 656 supports single pass duplex scanning.  I'm not at home at the moment, but can look at this later this evening.  It's not a "regression issue" and appears to be something related to your individual environment.
I'm sure there is a simple explanation as to why it's not appearing for you.
I'm running W11 24H2 and MF Scan Utility v1.21.0.2
ScanGear shows Feeder 2-Sided option
This issue is not related to firmware.
You need the 1st and 3rd drivers packages for full functionality.  Install the MF drivers (UFRII) with ScanGear first, and the MF Scan Utility v1.21.0.2 second.  The Master Setup is not needed.
It might be helpful if you give us some additional information.
How is the printer connected and to what?
When you "reinstalled" the software and drivers, did you remove the old device from Settings > Bluetooth and Devices, Printers & Scanners, first?
Did you uninstall the Canon software and restart your system before the re-install?
When you open the MF Scan Utility what appears in the upper right-hand corner of the drop down menu?  There should only be one  printer listed.
Please also look in Settings > Device Manager.  Expand Imaging Devices
What appears there?
Hopefully your answers to the above questions will reveal the issue.
I ran into the same issue with my MF455dw printer. It worked until I finally bit the bullet and updated Windows 11 to 24H2. I can scan duplex using the ADF with ScanGear, but only to JPG. I can do it from the printer to a network share to whatever format I want. MF Scan just doesn't work properly.
I'm a software engineer and former IT support guy, and I've tried all the tricks except a full reinstall of Windows, which I think is an unreasonable step to fix a scanner driver issue.
Greetings ,
While similar, this thread is someone else's topic and for a different model.  I have two MF series printers and installed them on several Windows 11 PCS running 24H2.  All have the option of performing single pass duplex on their ADF.  If you'd like assistance with your issue, please start your own topic.  Thanks in advance.
