Custom Paper Size Problem With Canon Professional Print & Layout
Alf_Tupper
I have a problem when creating custom paper sizes in Canon Professional Print & Layout. When I create a custom paper size in the appropriate window and click Ok, the new paper size is supposed to show up in the paper size drop down. In my case, it doesn't. That means I can't use that size for printing (at least, through PPL).
I have updated PPL To the latest version, restarted PPL, deleted the app completely and then re-downloaded it and restarted my Mac. No change except one. The new paper size was now showing up, but my only other custom paper size, which was there in the first place has now disappeared.
Both custom sizes are available if I go to through Lightroom or any other application.
Can anyone shine any light on this issue?
16 REPLIES 16
fparadisndip
Hi Terry
I finally found the way to add custom media in Professional Print & Layout (PPL) !!!
In addition of adding custom media with the Media Configuration Tool and updating the printer driver, you must do the following in PPL.
1) Go into the file menu
2) Select the "Other Settings" option
3) Click on the Add/Update Media Information (See print screen 1 below)
After these steps, I can select my custom media in the Media Type drop down list (see print screen 2 below)
Regards
Francois Paradis
Print screen 1
Print screen 2
Great Francois. Glad to hear it worked out in the end. Hope my answer was of some help, despite it being Mac based.
All the best.
Terry
Bruh, you RAWK! I was searching for a solution to this problem for hours and then found your post. It works! You saved me! Much appreciated ...
My pleasure! I had no idea my solution to my own problem would become so helpful to others.
Thanks-genius, it also works for the PRO 200. I find the software is not very user friendly. I'm sure many folks have floundered around this question.
Followed all the solutions above, but still couldn't change sizes of custom paper sizes in Pro-1000. Went online, chats, everywhere. Finally called Canon support.  Talked to an associate who worked with me for over an hour trying everything in his trouble shooting manual, to no avail.  Finally, as he was signing off, he suggested that I uninstall and reinstall the printer.  I was in the midst of a big project and was reluctant as I'm not a computer jock.  I took the leap and uninstalled the printer. After a short hiatus I reinstalled it using the installation CD that came with the printer.  When the printer was "ready for use" I opened the print dialog and hit paper size. Many sizes were shown along with Custom.  In the past when I hit this the sizes of paper had small limits to sizes.  When I hit it this time I was able to increase the custom paper sizes substantially and went on to print some panoramas.  Maybe an earlier upgrade was lost or corrupted and the reinstall fixed it.
BCQuinn
Same problem with Pro 200s.  This seems to be a software problem.  Canon’s UI is not intuitive.
