Canon Printer/Fax driver creating copies of itself and I can not delete it
LuizEmpire
I am having this problem with a Canon Printer,
I have the Canon Office Printer Utility installed and when I run it I can see the Canon Generic Plus UFR II V250(driver) with 4 copies of this same driver installed and I can not remove them, I need to have just one of them set.
I can see the same when I click print from any document.
8 REPLIES 8
Moderator
Moderator
Thanks for joining the conversation, LuizEmpire!
So that the Community can help you better, we need to know exactly which Canon printer model you're using along with what operating system is running on your computer (i.e. Windows or macOS, and which version thereof). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
@LuizEmpire.  I suspect you are running a version of windows?
Let us know which version and how the printer is connected to your system or network?
I'll tell you how you can delete the multiple printer instances once you have supplied the information requested above.
Hey, Shadowsports,
Thank you for your reply, I am sorry for taking that long to see it though.
In the PC we run Microsoft Windows 11 Pro x64 and the printer is connected via USB
Ready...  Here you go. 🙂
Close the Canon Print App
Press the Start Menu button
type "bluetooth and other device settings", select it from the menu
Now scroll down and look for "More Device and Printer Settings"
Select that. Now one by one, right-click on the duplicates, (copy1, copy2, copy3) and select Remove Device from the context menu.  When you open the Canon App again, they should not be present.
Thank you for that,
I will try doing it, Do you know what may be causing this issue though ?
Are you disconnecting and connecting the printer over and over again?  Using a hub, different USB port, etc?
Sometimes the printer stops working and we do a driver update and it might be connected to a docking station.
So yeah, I did it, I connected to the pc and tried to find those printers, but they don't show up, they were already delted previously, but they still show up in word for example.
