08-19-2022 11:17 PM
My new spectrum router doesn't support WPS. When I go under the Setup Menu/Wireless LAN Steup, it wants to search for a wireless router. 5 seconds later it tells me to press the WPS button on the router which I do not have. The only option it gives after is to press okay and it will try to WPS connect for 3 minutes. After all that, I finally get the Standard Setup option where I can select the Wifi network name and punch in the passphrase to connect. I've only seen it happen once where the Standard Setup option was available before the WPS option. I just updated the firmware to see if that would fix it but it did not. Is there a fix to access Standard Setup before WPS?
08-22-2022 01:14 PM
