Can't scan since upgrading to Windows 10: error message Code:9,244,3
JIS
I cannot scan since downloading Windows 10.  It says: You don't have the required privileges to access the specified folder Code 9,244,3
53 REPLIES 53
Johnny6
Hello,
I fixed that problem by changing user rights on profile folder.
I use a french Windows so I'm not sure about english terms.
Canon scan tool couldn't access to "documents" folder so it couldn't create scanned files.
I just added my own account in the security list and gaved it full access.
For security reasons, I just modified "documents" folder (instead of profile folder) that is the default folder used by my scan tool.
So right click on "documents" folder => Properties => Security => Modify => Add => Advanced => Search => Double Click on your own account => Ok => check Full access => Ok
 I changed my folder as suggested and it worked ONCE
2 weeks later I wanted to scan a document and I got the same old error code
I found that MICROSOFT actually has a scanner for free and you download it and it WORKS
NO MORE FOOLING WITH FOLDERS I guess
it is called the  WINDOWS SCANNER
O R
............WINDOWS FAX AND SCAN
anyway it worked at least this time,,, I just hope it keeps on working
go to microsoft store and get the free app
windows fax and scan
Hello ozexpat
Ten years. and hours of frustration, later your so simple solution solved my problem on an iMac. Thank you
