08-18-2026
07:25 AM
08:40 AM
James_C
My Canon PIXIMA G6020 ink cartridge facing some error not detected or incompatible cartridge
08-18-2026 08:37 AM
If your Canon PIXMA G6020 shows a “5200” ink cartridge/maintenance error, follow Canon’s steps in this exact order:
If the 5200 error comes back after doing the above, Canon indicates it may be fixed by replacing the print heads; if it still recurs after print-head replacement, you’ll need Canon service. manual.canon
Also, if your Ink Flush stops early (before it finishes), try running the Ink Flush again without doing an off/on power cycle in between—when users stop early, repeating the flush usually completes successfully. canon.com
Reply with the exact code text you see (e.g., “5200”, “B200”, etc.) and whether Ink Flush starts and then stops, and we can narrow the next step.
