Pixma MX922 Color Faded
thendreks
Recently the color prints are washed out / faded....ink levels are fine.
Anyone else experience this?
Hi thendreks,
Is the little red light on the Yellow and Magenta ink cartridges on or off? Also if you could attach a picture of your ink cartridges to your reply or just let us know all the information that is on the cartridge( ink number, where it was made, etc).
4 REPLIES 4
ArthurJ
Hi thendreks,
I recommend performing a nozzle cleaning. Please click HERE for the steps. Once the cleaning is done, you will be asked to print a nozzle check. Please compare the nozzle check to the one HERE.
I did the test and there is no output for Yellow or Magenta...both of them have ink left however. Please advise.
Hi thendreks,
Hello -
The levels from the app did not seem that low to be the culprit, however I did do a nozzle clean and then a deep clean, I then did get the ink level was low, so I swapped it out and alas now it's fine.
So ultimately the nozzles needed cleaning and the ink was low but not low enough to register a warning yet.
Thanks!
