01-22-2013 02:17 PM
Hello,
I am suddenly having problems with my S100. It will not take the picture when I press the shutter release. In case I had accidentally changed something, I did a Reset to Defaults. Then it worked, briefly, before returning to not working. It also would not let me change My Colors. Everything else seems to be working fine. Any ideas?
09-29-2015 08:22 PM
09-30-2015 12:59 AM
Thank you for the follow-up information and the consideration to let me know. The idea of installing a replacement part seems less daunting after this first repair. I wiil be prepared.
01-14-2015 05:39 PM
$160 ? Canon was selling refurbished S100's a few weeks ago for $139 !
02-27-2016 09:05 AM
The failure of the release button occurs in all modes. The focus mechanism is working. The release button failes in all lighting conditions. The problem used to be intermittent. Then it stopped completely. After not using the camera for several months it started to work again without interuption. For a good while now the release button is not working under all conditions and settings.
02-27-2016 07:34 PM
You can fix it yourself in about an hour, for under $20. Read earlier posts, starting with #400.
06-30-2016 12:16 PM
I have the exact same problem with my s100. Has it be determined yet that this issue is sytemic?
Thanks!
02-26-2018 05:17 PM
Turning off Blink Detection solved my S100 shutter problem
02-26-2018 05:25 PM
Yes turn it back on and see if it was a coincedence or a fix
02-26-2018 05:41 PM
So far a coincidence. I turned the blink detection on and the camera shutter still working. I will keep testing it for a few days.
02-26-2018 05:50 PM
Keep your fingers crossed! I bought a used working S100 for 3 reasons one was I got a Canon waterproof housing at a real cheap price for water and underwater shots, the price for the camera was also cheap and lastly there is a wealth of information on how to fix it now because of the chronic shutter problem. Last time I looked the shutter release problem thread was the second longest thread in the forum.
