07-17-2022 07:13 AM
Not sure if this is right place to post, but I have a Canon Powershot SX620 HS that randomly turns itself off after roughly 25 mins I think if I have left it videoing something for long periods > Yes, I have triple checked that ECO mode is OFF and so is Auto-shutdown , any ideas guys ???
07-17-2022 03:38 PM
Thank you, I was just in process of formatting card from eXfat to NTFS, luckily your reply means that exercise would be futile even if successful ( I was expecting camera wouldnt recognise that format ...... Thanks again
07-17-2022 09:32 AM
There is a 30 minute maximum record time limit. There is also a maximum file size of 4GB. It sounds like you are bumping up against one or the other. There is nothing you can do to change those limitations.
07-17-2022 03:38 PM
07-17-2022 06:10 PM
In a perfect world, you should formatting memory cards in the camera, not a PC.
