01-22-2013 02:17 PM
Hello,
I am suddenly having problems with my S100. It will not take the picture when I press the shutter release. In case I had accidentally changed something, I did a Reset to Defaults. Then it worked, briefly, before returning to not working. It also would not let me change My Colors. Everything else seems to be working fine. Any ideas?
03-28-2015 09:53 PM
Thanks for the update Wallygaw. For now I am happy that spraying with DEOXIT seems to fix it for me without further surgery. I will keep your solution in reserve in case of a relapse. I did notice when the problem first started that it was intermittent and pressing really hard seemed to help for a while -- until it didn't. Now it works just like new.
03-29-2015 12:00 AM
04-15-2015 03:17 PM - edited 04-15-2015 03:19 PM
eagerly awaiting your results for fitting your flex cable!
The part number is the same in the US- just called canon and its ~ $17 with shipping.
Would love to try to fix it myself, but have no idea where to start, especially if it involves solder :x
04-15-2015 03:32 PM
I got the part from Canon ~ $18 including shipping. Pay attention to which screw goes where, even though they are all itty bitty, they are all different sizes.
There were six outside case screws, a couple for the top piece that has the power button, etc., a couple for what might be the gps senser (it's a square piece that goes over part of the FPC part), and 2 little ones that are kind of through the FPC piece, but might not have needed to come out as the holes in the FPC may have been big enough to fit over the screws.
No solder involved. The old piece does have some sticky tape holding it down, so it needs pried off that in addition to the 2 slide in connections.
It was a little nerve racking disassmbling and not damaing anything else. My first attempt to power up after reassembly got no power. I hadn't wiggled the FPC connection that slides in the front of the camera far enough in.
Anyway, took a number of pictures at kids soccer game this weekend without issue. Should hopefully be good for a few more years:)
04-15-2015 03:34 PM
What was the specific part number? I want to make sure that that I order the correct part.
04-15-2015 03:42 PM
It was the part someone mentioned earlier, CM1-7226-000, description says FPC ASS'Y TOP.
I went through a couple of transfers to get to Parts the first time I called, but it looks like you can get them direct at 1-866-481-2569, 9am-7pm eastern.
It's crazy that a $10 part (much less for them at cost) is causing all of us such angst.
Good luck!
04-15-2015 05:56 PM
I just ordered the part, with the part number and phone number angeloweb gave. So far so good. Be careful, there are two cameras called S100. The one made 15 years ago is not ours.
04-15-2015 09:06 PM
04-15-2015 09:09 PM
I didn't heat it. What is there is like a thin 2 sided tape. I did not remove it, and it allowed the new FPC to be held in place.
Yes, the old piece is destroyed peeling it from that tape.
04-16-2015 04:21 AM
