08-02-2024
02:36 AM
08:08 AM
Hi, I have a Canon 600D. My problem is that my camera loses connection when I go to Live View. My camera is connected to the computer via USB and powered using an AC Adapter.
I have seen various posts here and some solutions that worked for them. Some are:
But none are working for me. The 3rd solutions seems promising as my camera 'loses' power when it tries to go in Live View.
Hope someone can help me. Thanks 🙂
08-02-2024 09:50 AM
What software are you using that "loses connection"?
08-02-2024 08:06 PM
Before, I was testing the connection out using EOS Utility 2. I also use my photobooth software called DSLRBooth. Whenever I go to Live View on both apps, the camera would suddenly disconnect.
08-03-2024 06:42 PM
Does it happen with a fresh battery? The sudden current draw might be too much for the AC adapter.
08-04-2024 09:35 AM
The connection is fine when using a regular battery pack. In addition, I tried the AC Adapter and USB setup on my laptop and it is working fine. The problem persists on my desktop computer.
08-04-2024 09:50 AM - edited 08-04-2024 10:01 AM
If it works on battery power, but not on the AC adapter, then I would suspect the adapter is the problem. Are you using a Canon battery eliminator and AC/DC converter?
Most of posts that I have replied to the user is not using a Canon battery eliminator. They are almost always using a cheap AC adapter, instead. Those tend to have problems ranging from ground loops to insufficient power output.
Users that build their own systems from a motherboard tend to have USB issues, too.
08-05-2024 05:14 AM
I am using an AC adapter that plugs to 220V. Can you show me a photo of a battery eliminator? I can't seem to find a reference photo on the internet.
As an additional info, I am using a computer system built by my supplier for a photobooth system. They tested it using the same model of my camera and they had no problem with any connection.
I tried the 'USB Mod' that I saw on one of the threads you replied to but I don't know how he made it work. The mod makes you cover with tape the 5V+ pin on the USB to remove incoming power to the camera. However, based from what I read, the 5V+ pin is needed for the connection to be recognized by the computer. So, now I don't know how he made it work for him.
08-05-2024 07:20 AM
It sounds like you are outside the US, so I do not have a link that I can provide for you. Your camera is an older model from 2011. Your camera needs the ACk-E10 AC Adapter kit, which I am uncertain if it is still available.
You should consult your computer supplier regarding this issue. It seems you have problems with your power adapter and possibly the USB ports on the computer.
08-06-2024 08:32 AM
Thanks for your inputs.
09-21-2024 07:02 AM
I am having the same issue with Canon 650D. I am using Mac using MacOS Sequoia and live view will disconnect while using Lightroom or DarkTable.
I can no longer use EOS utility as it is not supported for Mac Sequoia and it would help if an updated version of EOS utility can be Made available on the website. It has been long overdue since 2016.
Thank you,
Could you please advise on what could be the issue.
