07-23-2022
04:08 PM
04:14 PM
It seems that the SX720 I have just bought, will not connect to Apple El Capitan (10.11). There is not even a Driver for this function.
I would be happy to connect via a cable, but have failed to achieve this. I presume it is the upper connector (data cable). I have plugged this in, but my computer does nothing. (But the camera charges, so there is a connection).
How do I transfer photo images?
Also - what does the lower connector do? I have not found a connector that will fit, so what is this connector called?
RE
07-23-2022 04:30 PM
Run image capture.
Are you sure that it is a data USB cable and not a charging only abomination.
The lower connector is probably a mini-HDMI to connect a TV or monitor.
07-23-2022 04:28 PM
Where are you looking for software?
07-23-2022 04:30 PM
You also have the option of removing the memory card from the camera and using a card reader with your Mac.
07-23-2022 04:30 PM
Run image capture.
07-23-2022 04:40 PM
Thanks KV. You were right.
But now I am confused. The cable out of the Canon box would only charge. So I tried a cable from another product, and it worked. So why are Canon sending out 'charge only' cables with their camera??
Makes no sense. Anyway, seems to work now.
Thanks, RE.
07-23-2022 04:55 PM
@ralfellis wrote:Thanks KV. You were right.
Thanks, RE.
Where did you buy the camera? It was discontinued a number of years ago. Did you buy a used or refurbished camera?
