12-31-2020 12:33 AM - edited 12-31-2020 01:06 AM
Question: Can the GX 7 Mark III be powered by something other than the battery when the USB-C port is connected to the computer as a webcam?
Setup:
Is there a product or way to power the Mark III so the battery does not run out?
01-06-2021 04:01 PM - last edited on 01-06-2021 04:05 PM by Danny
@adayley wrote:
@John_ wrote:Might have to chalk this one up to an error on the Canon website?
We shall see how my Mark III reacts when the generic "dummy battery" power adapter gets here in a couple of days.
The Canon website is NOT in error!
I ordered this power adapter from Amazon: Glorich ACK-DC110 Replacement AC Power Adapter Kit for Canon PowerShot
It arrived today. I took just a few minutes from my busy day quickly check how it works for the PowerShot GX 7 Mark III.
It powers the camera while the battery compartment door is still open!
So, now I only have to worry about mounting the camera in a way that is stable while the battery compartment door is open to allow the cord to enter.
[link removed per forum guidelines and replaced with screengrab]
01-01-2021 02:05 AM
@adayley wrote:
@John_ wrote:Ahhh oh yes I see it. Still, I do not see how it will work if you cannot close the battery door? The manual mentions a USB Power Adapter PD-E1
Can't use that adapter and USB for video at the same time. Maybe the only way to externally power the Mark III and use it as a webcam is to have the video come through HDMI. That way USB can provide the power.
Take a look at the door to the battery compartment. Is there a rubber flap on it just big enough to allow a wire to pass through?
01-01-2021 11:49 AM
@Waddizzle wrote:Take a look at the door to the battery compartment. Is there a rubber flap on it just big enough to allow a wire to pass through?
Mark III does not have that flap.
01-01-2021 11:55 AM
As you can see from my original repy, the MKIII is listed as compatible, but if you say there is no flap then it won't work.
~CarePaks Are Worth It
01-01-2021 02:20 PM
@shadowsports wrote:As you can see from my original repy, the MKIII is listed as compatible, but if you say there is no flap then it won't work.
If it is compatible, then it should work somehow. I looked at the battery door at B&H, and there is no flap.
01-01-2021 02:56 PM
01-01-2021 04:32 PM
01-06-2021 05:44 PM
That is interesting, I wonder how it bypasses the battery door switch interlock.
01-06-2021 06:29 PM
@John_ wrote:That is interesting, I wonder how it bypasses the battery door switch interlock.
I ASSUME the battery door switch interlock is software controlled in the Mark III. And the system can tell if the power device is a battery or a dummy battery.
If battery then honor interlock switch,
else if dummy then ignore interlock switch.
01-06-2021 06:38 PM
Yes, that would be a solution in any case It's good that it worked out for you.
