Powering G7 X Mark III when used as USB webcam?
adayley
Question: Can the GX 7 Mark III be powered by something other than the battery when the USB-C port is connected to the computer as a webcam?
Setup:
  • Laptop has the EOS Webcam Utility installed.
  • GX 7 Mark III is connected via its USB-C port to a USB port on the laptop.
  • The Mark III is operating correctly as a webcam.
  • The Mark III cannot be powered using its USB-C port because that port is the video data interface.
Is there a product or way to power the Mark III so the battery does not run out?
24 REPLIES 24
Yes, that would be a solution in any case It's good that it worked out for you.
Miroslava
Hey just want to ask if this dummy battery from amazon for canon g7x mark iii works while streaming. Iam looking for dummy battery for 3 days and didnt find anything.
I'm not sure which dummy battery you are asking about. I am successful using the dummy battery mentioned in a previous post in this thread.
Amazon: Glorich ACK-DC110 Replacement AC Power Adapter Kit for Canon PowerShot
Miroslava
Can you please send the link again please ?
This forum does not allow links in postings. Just search Amazon for "Glorich ACK-DC110" to get the item at the top of the list. Should look like this item:
