01-24-2024
12:36 PM
08:45 AM
I have been searching for a way to upgrade my G7X to the latest firmware. I see there is a post regarding this here:
The issue that is not mentioned is that the G7X does not have a "firmware update" in the tools menu. It doesn't exist. I believe I read somewhere that the only way is through a piece of Canon software, but I am trying to confirm this.
I have followed everything on the thread mentioned above, but as I said, when I put the SD car din the camera and to on the playback mode and look at the tools menu, there is no firmware update selection.
Thanks
01-26-2024 01:39 PM
I am reading that it might be due to the type of SD card and/or card reader/writer. I think the "update firmware" selection ONLY appears if the camera sees a properly formatted version of firmware in the SD slot?
I will try a different SD card, not sure if I have a different read, but I can try it through a PC rather than my Mac
01-26-2024 01:57 PM
It may be due to your camera not being in the correct mode. Try switching it to either Program (P) or Manual (M) mode and see if the firmware menu now shows up.
01-26-2024 03:36 PM
It doesn't show up in "P" or "M" mode
01-28-2024 11:54 AM
01-28-2024 11:59 AM
OMG, it just worked! I was looking at the wrong menu? I thought is was in the tools menu, but it is in the playback (blue) menu. I hope that anyone reading through this will get a heads up.
