PowerShot SX740HS Firmware Update Issues
TheMoonman
Folks- I am having an issue updating the firmware on my SX740HS. I have downloaded the file to my computer. I have tried placing the zip file on the memory card in various folders using my computer. No matter where I place it on the memory card, when I return the memory card to the camera, and try to update the firmware, the camera tells me that there is no firmware on the card. Any suggestions? The instructions from Canon are not helpful.
6 REPLIES 6
normadel
You don't put the ZIP file on the SD card. You unzip it on the computer and put the DRIVER FILE on the SD card.
To add...
The file you need to copy to your SD card is this.
SX740HS143.FIR
It's file extension is .FIR. It's inside the zip which you need to extract (unpack)
TheMoonman
Thanks normadel and shadowsports! I got it loaded.
normadel
You're welcome. Please accept our answers as solutions.
Incidentally, Canon provides detailed, clear directions with the download.
TheMoonman
Not really.
I am also having problems with the camera recognizing the firmware.  I was even on the phone with Canon Support and they were not sure why it would not recognize the firmware.  What did you do that your camera all of a sudden recognized the file on the SD card?  Thanks,
