Overexposed PowerShot SX410 IS
Binsoy
I reset the settings, i lowered the iso, And nothing. Still taking overexposed pictures, but filming is fine
6 REPLIES 6
John_Q
Hello Binsoy,
Are the images still overexposed when you shoot in the Auto mode after resetting the camera to default settings? If so, there may be an issue with the camera. I would suggest contacting our phone support for more assistance on what options you would have in that case and maybe some hands-on troubleshooting. Please contact our Technical Support Team at 1-800-652-2666, Monday through Friday between 9:00 am to 9:00 pm ET.
normadel
Lowering the ISO will result in MORE exposure, not less.
No; lowering ISO values is akin to closing down (narrowing) the aperture or using faster shutter speeds.
Ricky
normadel
I meant lowering the ISO will tell the camera to open the lens or slow the shutter. More exposure.
But the end result would be the same, wouldn't it?
It's not clear what mode the OP was using.  But it sounds like it wasn't fully auto since they were able to manually adjust ISO.
I'm sure I follow what you're describing though in terms of lowering ISO will lead to more (higher) exposure.  It wouldn't.   Exposure would either stay the same or would be lower.   Here, I'm assuming the camera will be allowed to adjust shutter and/or aperture automatically.
For simplicity sake, let's assume the lens only has two apertures (f/4 and f/5.6) and the camera has two shutter values of 1/100 and 1/200, and three ISO values of 100, 200 and 400.
If a shot is taken at f/5.6, 1/200 and ISO 400 that leads to a good exposure, you can lower the ISO by two stops and the camera will adjust the aperture and shutter by one stop each.  So the equivalent exposure would now be f/5.6, 1/100 and ISO 100.   No increase in exposure at all.
Then, say that at f/5.6, 1/200 and ISO 400, the image is overexposed.  By lowering the ISO to 200 (here, the camera wouldn't stop down the aperture or increase the shutter since already at their limits) the exposure would decrease by 1 stop (-1EV).   Then -2EV if lowered to ISO 100.
Ricky
Nica
I also had this problem but when I take videos or to film, the outcome is fine.
