07-22-2023 09:32 AM - last edited on 07-22-2023 09:36 AM by Danny
I need help updating my ixus 190. I have followed the instruction but when I put the card into the camera and look at the menus there is not an option to update firmware. Anyone have any ideas?
07-22-2023 10:05 AM
Are you following these instructions?
IxyPSelphIxus_Firmware_Update_Procedure_EN.pdf
07-22-2023 12:03 PM
Yes I am everything goes ok until the last bit I put my card in and follow instructions but when the menu comes up there is no firm update under resume.
07-22-2023 01:12 PM
Are you putting only the .fir file on the card and in the root level (where you see the Canon folders)?
07-22-2023 02:03 PM
The card was formatted and empty and I have been only putting the file into it. There is only the 1 item on the card showing on the computer before I put it back in the camera.
07-22-2023 03:52 PM
Try formatting in canera and then transferring the .fir file onto the card.
If that doesn’t work give Canon a call. You should be able to find the support number for your country on the site where you located the file.
