10-09-2015 05:00 PM
I cannot get to Live mode..When I push the up arrow I get only auto or monochrome. Had it yesterday but cannot remember how I got it
10-09-2015 09:01 PM
10-09-2015 06:32 PM - edited 10-09-2015 06:43 PM
You have to push the up arrow more than once...have you tried that ?
Also Live veiw may not be available depending on the settings you have have selected. Starting on page 194 and forward you can see which settings will block live veiw. There are many of them.
You can try a reset to defaults if you are not sure what may have changed
10-09-2015 07:30 PM
Thx but I do not have page 194 in the user manual...but i think I finally figured it out
10-09-2015 07:47 PM
Well thats good then!
You can download your full user manual from Canon at the link below. The full manual is over 222 pages under the Guides and Manuals heading
10-09-2015 07:59 PM
Thanks John..there are two areas for the manual and I picked the one thatwas 119..you have been most accomodating and I want you to know it is very much appreciated.
10-09-2015 09:01 PM
your welcome !
12-06-2015 09:45 PM
I have the same problem. I have pressed the up button many times, and it only toggles between AUTO and P. I have looked over the manual and not found any unacceptable settings, and I have reset to defaults. It still doesn't do LIVE. What should I try next?
12-08-2015 05:32 PM
Hi Vt3,
You may set the "up arrow" function to a number of modes. In this case, you've chosen "P".
To change this, set the camera to "P", then press the FUNC SET button. Now, go to P and press the RIGHT ARROW button, then use the UP or DOWN ARROW to select "Live" (or other mode of your choice. Now press the FUNC SET button.
12-08-2015 10:53 PM
yep -- that was it.
