Reply
Occasional Contributor
iP4700 Pixma - Distorted Lines of Text When Printing
I am having problems with distorted text printing with our IP4700. It is more prounounced when 'fast printing ' is set in preferencs, but is beginning to occur with normal printing as well.
Here is a test Word document (Arial 10 pt) with 0.5" margins all around, 2 equal columns of 3.6" with 0.3" spacing. This allows the 26 letters of the alphabet to exactly fit across the width of the column so the document is 'uniform' in appearance on the monitor. Both columns are similar and fit on one page if the final paragraph mark is selected and set to 2 pt.
I've placed a scan of the page in Imgur at this address:
Full Page Display
I selected a small portion in PSE and circled examples of  a 'perfect' letter 'l' and a distorted one and placed it here:
Detailed Section of Image
Also look at the bottom line of text in this detail and observe the 'offset to the right' of the descender portions of the letters 'j,' 'p,' and 'q.'
Can any one tell me what is wrong with our printer? Is there a 'fix' that I can apply?
thanks,
baumgrenze
Re: iP4700 Pixma - Distorted Lines of Text When Printing
Hi baumgrenze,
You can try performing a print head alignment on the printer to see if this will resolve the issue being experienced.  To do this, please follow the steps shown here.  Should you continue to experience difficulty, we ask that you please contact a Canon technical support representative here for further assistance. A representative will be happy to assist you free of charge.
Ramona,
Thank you for your reply. I did both the 'automatic' and the manual print head alignment. The results are much improved. I still see problems which I have marked with red arrows in the image below.
Should I repeat the manual alignment multiple times, or are repeated tries pointless?
Help me understand. I know the printer is fast. Does the print head print multiple lines at a time or is each line of text composed of multiple passes? Is there perhaps not a correlation between 'lines of text' and print head passes on the page? Are the discontinuities I marked created by separate passes where there is a slight print head alignment error?
I know it is Canon's business to sell new printers, introduce new technology, but I like this printer and would like to keep it running. It prints lovely pictures.
As you can see there are black lines to the left. My wife made them for me to help me know where to look for problems.
My eyes naturally distort text and any distortion added by misaligned printing really hinders my ability to read so I'm trying hard to get as good a print job as I can.
Thank you in advance for your further explanation.
baumgrenze
Since I posted the above reply, I realized that I had missed a linked knowledge base document in your reply.
Please consider a more contrasting color (Word uses blue vs black) to help those of us who do not see so clearly that there is a link. I should have realized it was implied in the words of the text, but I missed it the first 2 times I read the paragraph.
It is late for me to run through the test tonight. I will try it tomorrow.
What I did yesterday was to recall that I'd seen this menu before and that 'Printer Properties' contains a 'Maintenance' page and that the color pages weren't just an 'automatic process' but an interactive one.
In the end, I did the manual alignment twice because it seemed to be having a positive effect on PGBK text printing.
Just some suggestions.
I will report my experience once I have time.
thanks
baumgrenze
Today I finally found time to run through the alignment properly. My alphabet test printed cleanly with the printer properties set to 'normal' but showed the abnormalities I described above when I selected "Fast (Speed Priority) in the properties (upper right corner of the Print menu.) Should I anticipate encountering this tradeoff if and when I elect speed (and ink savings) over quality?
Once this question is answered, I consider this help request to be Solved!
thanks
baumgrenze
Hi baumgrenze,
Selecting "Fast" should not cause the issue that you are experiencing to occur.
Please try cleaning the encoder/timing strip of your PIXMA iP4700.  To clean this part, please follow the steps outlined in the Knowledgebase Article below.  The article is for a different model, but the steps to clean the encoder/timing strip are similar:
https://support.usa.canon.com/kb/index?page=content&id=ART143651
After cleaning the encoder/timing strip, please print again.
If the text still does not print correctly, please contact our support group using the following link:
http://Canon.us/ContactLI
Patrick,
Thanks for your reply. I looked at the KB article and want to confirm that I have found the "encoder/timing strip" so I took some photos. They are grouped, in order, at this url on Imgur:
http://imgur.com/a/CHPqs
The first two images show what I have concluded is the "encoder/timing strip." Please confirm. Also confirm that what might be a logo is in fact 'dirt' that should be cleaned off.
In the KB I am told to use a 'neutral detergent' to clean the strip. Does a pH 8 +/- 0.1 dishwashing detergent qualify? Would something like Woolite be better?
The third image is of what I believe is the 'rail' mentioned in the KB. Where the carriage for the print head and the ink tanks passes sideways across the printer it seems to 'ride' against the 'rail.' I see what is either a black lubricant or gummy black ink that needs to be cleaned off. Which is it?
In the photos I noticed that the white paper transport rollers are dirty. They are featured in the fourth photo. Can they, should they be cleaned? Would rubbing alcohol on a swab be appropriate?
Finally, in the past I've seen suggestions that I monitor the 'sump' or 'ink dump' where the priming ink from head cleaning is deposited and also the 'parking place' which I believe the head contacts when it is not printing so that the ink does not dry out. The last image I think I see both of these. Is the one farthest to the right the 'parking place' and the larger, nearer one the 'sump or dump' for waste ink? Do these need maintenance? is there a KB covering this topic?
thanks
baumgrenze
Hello.
Gently clean the encoder strip shown in the first image.
Dawn is considered to be a pH neutral detergent.  Use 2-3 drops in a 1/4 cup of water.
Avoid any contact with the rail whatsoever.
You can try cleaning off the white rollers.  However, avoid touching the rest of the pads or sponges.
If you experience any difficulties or have more questions, please contact our support group using the "Contact Us" link below for additional assistance with this issue.
powered by Lithium
