05-26-2019 07:04 PM
I cannot scan documents to the printer or to the emails in my address book. I keep getting error message on transmission. documents feed correctly. Also, I expect to see each page in my computer but I don't. Is there a driver I need to scan documents into my computer?
Thanks.
vishnu1
05-28-2019 01:05 PM
Hi vishnu1.
If you are attempting to scan documents to the computer, you will need to install the scanner driver, and also use the MF Scan Utility.
If you are using a Windows computer, then the drivers are installed along with the printer and fax drivers by clicking the link below:
MF240SeriesMFDriverV2175W64usEN.exe
You can download and install the MF Scan utility by clicking this link:
If you are using a macOS computer, then the scanner driver and software will be installed using the same file. Please click the link below to install the files:
Scanning to email addresses does not require a driver, but the printer will need to be connected to the wireless network. To perform the scan to email setup, please follow the instructions at the link below:
Configuring Basic E-mail Settings
NOTE: You will need to refer to the settings for your email service provider to perform this setup.
If you still continue to experience an issue, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
