07-08-2023
06:08 PM
06:10 PM
SamanthaW
mf244dw. i am sure therere is a setting in the utility setup, but either i dont understand or (maybe) it is unclear. any suggestions welcome.
12-27-2023 02:44 PM
Hello,
If the issue is sporadic, it could be caused by a service not responding on the computer or a drop in communication. If plugged into a USB hub, you can connect the printer directly to a port on the computer. Instead of reinstalling, you can try restarting the Windows Image Acquisition service to see if the scanner buttons respond.
You can press the Windows key and the letter R key at the same time on your keyboard. In the run box that appears, you can type in services.msc and click OK. In the list of services, you can highlight the WIA service and then click restart.
If that does not resolve the issue, I would suggest contacting support over the phone at 1-800-652-2666. Our agents would be happy to assist with checking what might be causing the issue.
10-12-2023 01:46 PM
Hello,
To scan from the operation panel, you can follow the steps in the link found HERE. When you get to step 4, you can select your computer from the list that appears. If your computer does not appear, you can try power cycling the router that connects the devices and turning the printer off and on to see if it appears in the list of PCs that you can send scans to.
We would be happy to assist with the issue. To provide some feedback or some troubleshooting steps, we would need some additional information. If you could reply to this message with the information below, we can provide some assistance. For a more immediate resolution, you can contact support over the phone at 1-800-652-2666.
10-12-2023 01:52 PM
Hector, thanks. this is a USB connection, and the printer function is ok. it's just the scan buttons that stop functioning.. i am using windows 10.
and the issue is sporadic - weeks can go by with no issues; then the device scan button does not communicate. i've gotten it to a 5 minute process to uninstall the devices and reinstall the drivers from downloaded executables, so it's more a matter of curiousity now, rather than an urgent problem.
12-27-2023 02:44 PM
Hello,
