06-25-2021 10:13 PM
I've been having an intermittent problem where my newish mf743cdw, purchased in November, gets stuck on the Autoclean Fixing Assembly and hangs and checked the latest drivers at https://www.usa.canon.com/internet/portal/us/home/support/details/printers/color-laser/color-imagecl...
I can't even figure out how to tell what the installed firmware version is - does anyone know?
And the printer driver site doesn't go into any detail about what's in the v 7.12 update, which is from May 6, 2021, and is therefore presumably newer than whatever I have on my machinge that I purchased in November of 2020.
Any comments on whether I should install it? I generally don't like upgrading firmware unless I have a reason to think it will fix a problem.
06-26-2021 11:03 AM - edited 06-26-2021 11:07 AM
I suggest you start here:
Check FW Version here:
Manual / Auto Fixing Assembly Cleaning / Settings here:
I don't neccessarily feel a FW update will solve or is the solution for your issue, but here are those tools for Windows & MAC.
Support | Color Laser | Color imageCLASS MF743Cdw | Canon USA
A newer printer driver (7.1.2) won't hurt, but Its not going to change the fixing error message.
06-26-2021 11:06 AM
Thanks, shadowsports
08-13-2021 04:00 PM
Hello David07666,
This issue would usually point to a problem with the hardware or one of the toners in the printer. In this situation I would suggest trying to reseat the toner cartridges using the steps in the link provided HERE.
We would be happy to assist further with the issue. To provide some feedback or some troubleshooting steps, we would need some additional information. If you could reply to this message with the information below, we can provide some assistance.
For a more immediate resolution to the issue, feel free to contact support at 1-800-652-2666. Our agents would be happy to help.
08-14-2021 08:39 PM
Thanks, Hector. I'll try it the next time I run into this problem.
