03-08-2020 05:27 PM
HI - I have had my printer less than a year and it's recently started making a crazy loud grinding noise when I send something to print. I thought maybe it's the printer cartridge but they're all showing that there's over 1/2 ink left in each.
Any ideas?
What brand ink do people recommend?
Also - a 'tray' has detatched - think it's to do with the paper tray but where can I find images/diagrams of set up to see how it fits back into the printer.
ugg - Help!!
03-09-2020 09:56 AM
Your printer has a 3 yr warranty. As far as us trying to diagnose the sound you hear, thats going to be difficult through a support forum.
You can try making a video if you like... But is may be hard to determine the source however.
I recommend Canon toners. They cost a liitle more but will work best with the printer.
The manual might be the best place to see about loading paper and the location of the trays.
http://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDMwMDAyNjgzMDA1&cmp=ABR&lang=EN
03-09-2020 04:48 PM
Hi AMASSY.
For a grinding noise, I recommend firstly opening the printer to where the toner is. Pull the toner cartridge holder out, then check for any jammed paper. If none is found, check that each of the toner cartridges is installed correctly, and that all packaging has been removed.
If the problem persists, our support is available at 1-800-OK-CANON (1-800-652-2666) Monday-Friday from 10:00 am to 6:30 pm ET, excluding holidays.
03-09-2020 06:06 PM
03-09-2020 07:58 PM
Hi - thanks for your reply also.
I've checked there isn't a paper jam.
I've changed one of the ink cartridges as it was a different make to the other three. I've double checked there's no packaging left.
As soon as I close the front door it tries to do something - I haven't sent anything to print. It just grinds loudly and doesn't stop.
I took a video but can't upload it for some reason.
03-09-2020 09:06 PM
I think I should have an expert look at the printer. How do I do this? Can I request a callout through this forum or do I need to take it to a Canon office? i bought it at a Best Buy - should I go there??
03-10-2020 08:28 AM
03-10-2020 06:25 PM
okay - many thanks
03-13-2020 06:10 PM
Hi AMASSY
Canon Support can help you find and arrange for support options. If you're in the US, refer to the number posted above, otherwise you may find your local branch of Canon using the Canon Global map: http://global.canon/en/support/
11-27-2020 09:06 PM
Mine does the same thing. Did you get any answers?
