Glossy Paper and Laser
mes8487
I have 9 inkjets but decided to buy a laser, LBP622CDW. I am a small business owner and use a variety of papers/cardstock.
Years ago I had an Oki which printed on everything and I thought the 622 would do the same but it doesn't. I particularly use paper and cardstock that is glossy but it just comes out a mess. I called Canon and they said not all laser printers will do glossy. Any suggestions?
Along with that, i tried 80lb gloss text on my Pro 100. It was meant to go on the laser. On the Pro 100 it was usable but colors and depth of colors was a bit off. Any tips?
2 REPLIES 2
I have a pair of these arriving today.  Purchased for 2 labs that will use for standard document printing and for printing test tube labels.Those will  be glossy.  Won't have them in operation for about 8-9 days, so probably can't advise.
Paper intended for inkjet cannot be used with laser and vice-versa...  I mean it will print, but how the ink looks might not be what you want to see.
I have used glossy paper intened for laser printers many times without issues.
OK, I have my 2 LBP622dw's installed and configured.
I set up using the printers control panel initially, but switched to the remote UI.  If you set a PIN for security, make sure you remember it.
I've run plain and glossy artsy type photo paper through both.  No issues.
