imageCLASS MF743Cdw How to set Paper Tray Default
MMMHouston
I have a relatively new Canon ImageclassMF743cdw.  I print from my personal and my work laptop.  Several days ago, I used the multifunction paper tray for the first time to print a legal size letter. Since then, I cannot get the printer to automatically print to the other tray (the one with 8 x11 paper).  It beeps, makes me select the paper tray and then it will print.  This makes me crazy since I hadn't changed any settings on the machine.  I have checked all the settings and Tray 1 (letter) is the default.  What am I missing?  Anyone else have this issue?  I want it to automatically print to Tray 1.
Darius
Whiz
Hi MMMHouston.
First, verify that the paper size is set correctly for the drawer:  https://oip.manual.canon/USRMA-3547-zz-SSM-740-enUS/contents/devu-basicope-papers_pset-psize_ptype-p...
Next, ensure the Paper Source options match in the printer's driver (on the computer).  If there is a conflict, the settings on the computer will override the settings on the printer, which may cause the printer to require you to confirm paper settings manually.
4 REPLIES 4
Darius
Whiz
Hi MMMHouston.
This did not work for me.
I have wasted so much damned time on this. the page, the computer, the printer set to legal ...everything saved .. still won't print correctly. Garbage
Hi, CP1!
Welcome to this four-year-old thread! You'll want to verify you have the current drivers and software installed from our site here: https://canon.us/MF743Cdw
If everything is current and you still need help, call support at 800-OK-CANON (800-652-2666) during the week.
Friends and Family
