10-26-2023
02:46 PM
09:29 AM
I have printing quality issues on right side of the paper, does anyone know what happened and which parts I need to replace? Thanks
01-10-2024 03:47 PM
Hello Mingpan,
It looks like the printer needs to be cleaned or there is a problem with the black toner/hardware. In this situation, you can try cleaning the ITB and fixing assembly to see if that resolves the issue. If not, you can try reseating the toner cartridges and checking if any are leaking/damaged. You can also try another black toner cartridge to see if it resolves the issue.
05-12-2025 09:28 AM
Hello Hector,
I am having the issue above. The smudge looks exactly the same in terms of location and frequency on the page. It always contains a portion of the underlying image and may be in black or in color depending on the image. I have tried all the suggested fixes, and used all the service cleaning options on the printer. I have exchanged toner cartridges and checked for toner leaks. No issues found. It's almost like something is sticky on a paper contact part that is picking up toner from the image before it's fixed. Help would be appreciated. Thanks, Mike
05-12-2025 09:34 AM
Hello!
I’m sorry to hear that you’re having trouble with your printer. Since this thread is a couple of years old, to help the community assist you better, we need a bit more information:
- What is the exact model of your printer? (It can usually be found on the top or front of the unit.)
- Are you seeing any error messages?
- Which version of Windows or macOS are you using?
- How do you connect to your printer: via USB or Wi-Fi?
- Are you using Genuine Canon toner?
Any additional details you provide will help the community better understand your issue.
If you are in the United States and need urgent support, please click HERE to visit your My Canon Account for personalized support options.
If you are outside the USA, please click HERE to find support options for your country.
Thank you, and have a great day!
05-12-2025 09:37 AM
MF733CDW, No error messages, Mac OS Sequoia, WiFi, Absolutely your cartridges.
