10-27-2024
08:51 PM
11:36 AM
So, I have the Auto Image Adjust Regularly set to OFF, and the Auto Correct Print Color Mismatch set to When Turning Main Power On.
I never turn the machine off. Sleep is set to 15 minutes. I thought that meant that neither adjustment would be made until I do turn the power off, and then on again, in which case it would do a Correct Print Color Mismatch.
Yet, before the first print job of the day, or the first print job after it has been asleep for several hours, it goes through some type of process for maybe half a minute, then stops, then prints the job.
Does anyone know what it is doing?
Edit: By the way, I don't really understand what correcting "after the first print job" means. So if I don't turn off the printer for five years, it will do the correction the first time I printed after first turning the machine on and not do an auto correction again for five years? Who writes these things?
Thanks.
11-07-2024 08:45 AM
I agree. I hate that the printer is constantly recalibrating. I use my printer for different size paper as well. and even though I have entered in the custom sizes or used from list, it calibrates and asks me to choose a size between each document. And even though it says it should hold 50 sheets in manual feeder, it does not, and it calibrates between EACH PAGE. 😢😒
11-07-2024 08:54 PM
We use our 656 almost daily. Mostly 8.5x11 and sometimes larger for spreadsheets. I've seen a recalibrating message maybe once in the last 8-9 months. I've had this printer since Feb. this year and the 644 since 11/2023. Its never displayed a recalibrating message I am aware of.
The ADF in both models does indeed hold 50 sheets. I use the manual feeder for an occasional envelope.
These are my Paper Source Auto Selection Settings
Driver Control Panel looks like this
The printer will occasionally take a few seconds to warm up (first print of the day), but its under 30 sec. I leave the printer on 24x7. Default sleep 1 min. I need a way to reproduce the issue. Neither of my devices display these behaviors at all or with any regularity. I use Canon toners.
~R5 C (1.1.2.1), ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw MF656Cdw ~Pixel 10 ~CarePaks Are Worth It
08-20-2025 10:50 AM
Hello,
If the printer has not been used for several hours, it will usually need to warm up before printing. If you have the auto correct turned off, it would not perform a color correction but you can start one manually using the steps in the link HERE.
We would be happy to assist, but we would need some additional information to assist further. You can reply to this message with the information below and we can provide some troubleshooting steps or suggestions. For a more immediate resolution I would suggest contacting support over the phone at 1-800-652-2666. Our agents would be happy to assist.
1. How many hours does the printer sit unused before the delay issue occurs?
2.What does it show you on the printer display when this happens?
