imageCLASS MF644Cdw - Spinning and stuck after changing the black cartridge
billg118
Ive had this for about two year and have replaced the toner before with no issues. Today I replaced the black cartridge.
When I close the front of the printer I can hear something spinning non-stop.
At the bottom of the screen I see on "Correcting... wait a moment.". About every 30 seconds theres a big plasticy knock that comes from the machine.
I tried putting the original cartridge back in and it does the same thing. What do I do here?
Hector
Hello Billg118,
It looks like there is something wrong with the hardware or the toner cartridge is causing an issue. In this situation, you can try removing all of the toner cartridges and leaving them out of the printer. After that, you can unplug the printer from the power and then press the power button 10 times while the printer is unplugged. After that, you can plug the printer in and then turn it on. Once the printer is back up, you can reload the toner and check if it has resolved the issue.
If you continue to have the same problem, I would suggest contacting support at 1-800-652-2666. Our agents would be happy to see what might be causing the issue and can provide any service options
2 REPLIES 2
Hector
Hello Billg118,
billg118
Thanks Hector,
I tried all of that and tried putting the old cartridge back in. None of that fixed it.
I put the new one back in and very wiggled the tray around and it worked again. Might be something wrong with the mechanism on my tray.
09/19/2022: New firmware version 1.0.4.1 is available for EOS C70
08/31/2022: New firmware version 1.1.1 is available forRF 70-200mm L IS USM
07/28/2022: New firmware version 1.2.1 is available for EOS-R3
07/21/2022: New firmware version 1.6.0 is available for EOS-R5
07/21/2022: New firmware version 1.6.0 is available for EOS-R6
07/21/2022: New firmware version 1.1.0 is available for EOS-R7
07/21/2022: New firmware version 1.1.0 is available for EOS-R10
07/01/2022: New firmware version 1.3.0 is available for PowerShot PICK
06/07/2022: New firmware version 1.0.3 is available for EOS M50 Mark II
04/26/2022: New firmware version 1.0.1.1 is available for EOS R5 C
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
01/05/2022: Welcome to CES 2022!
