04-13-2022
03:34 PM
08:40 AM
ImageCLASS MF445dw printing "GET ?eSCL/ScannerCapabilities HTTP/1.1 Host: localhost" many times a day wasting paper and i cant get it to stop! I have reloaded the software multiple times. Once it did stop until we had a brief power outage and now it is back and will not stop. Using windows 11.
08-22-2022 04:41 PM
Hello,
An NG result for faxes will point to a problem calling the fax number or a problem with the phone line connection. In this situation, You can try checking the fax line on the fax machine to make sure it is properly connected or try sending a fax to a different number to see if it goes through.
If that does not resolve the issue, I would suggest contacting support at 1-800-652-2666. Our agents would be happy to assist with the fax connection and can provide any service options.
09-14-2022 08:32 AM
exactly same issue. paper wastage.
i used the machine on wireless connection earlier and this never happened. but then the printer started losing connection randomly after a few months. prints would come out after a random period of about 30 mins or so. nothing on our network had changed, including the physical location of router and printer.
i switched to usb coz of this, and now the machine does random prints. it would have made more sense if it printed "I AM NOT GOING TO LET YOU LIVE IN PEACE"
09-22-2022 01:28 PM
Hello Fowzan,
The issue you are describing will usually point to a problem with the drivers used via USB on a Windows computer. To resolve this I would usually suggest uninstalling the MF455 drivers and then disconnecting the USB. Once disconnected, you can try installing the recommended driver from our support site.
If you continue to have issues or need assistance with the uninstall reinstall process, you can contact support at 1-800-652-2666. Our agents would be happy to help.
