03-26-2023
05:06 PM
09:20 AM
my menu window on my mf260 printer came up in chinese and i can not change it back to English.
03-28-2023 07:21 PM
I had to re-initialize. I hit
Menu
3 down OK
down to bottom ok
left button ok
Make sure to put in a PIN when you set it up again
Good luck
05-14-2023 08:02 PM
I just fixed mine back to English - hopefully you're already fixed, but just in case here's 2 different ways to try and fix it.
Option 1
Press Menu button > Down 3 times > Ok > Down to bottom > Ok > Left > Ok > Left > Ok > Wait and cross your fingers and toes!
Option 2
Press Menu button > Down 3 times > Ok > Ok > Ok > Down 2 times > Ok > Ok > Left > Ok > Again cross fingers and toes!
05-16-2023 12:51 PM
If the steps to change the display language are not working and the printer is set to another language, it could also point to a problem with the hardware. In this situation I would suggest contacting support over the phone at 1-800-652-2666. Our agents would be happy to check what is causing the issue with the language setting and can provide any available service options. There would not be a charge for support over the phone for a new printer. To call in the printer will need to be registered to your MyCanon account.
04-18-2023 10:27 AM
I have this same issue. My printer is also brand new. Is there a fix?
05-14-2023 08:04 PM
In case you don't get notifications unless I reply to your post directly, this is the same instructions I just shared with Leanie725. Best of luck!
Option 1
Option 2
