03-26-2023
05:06 PM
09:20 AM
my menu window on my mf260 printer came up in chinese and i can not change it back to English.
03-28-2023 07:21 PM
I had to re-initialize. I hit
Menu
3 down OK
down to bottom ok
left button ok
Make sure to put in a PIN when you set it up again
Good luck
03-28-2023 09:57 AM
Hi, marlowe!
So that the Community can help you better, we need to know exactly which Canon printer model you're using. "MF260" can refer to any of several printers in the imageCLASS MF260 series. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
03-28-2023 05:23 PM
My printer is the ImageClass MFC264 II
Same problem. All menus are suddenly chinese.
Cheers
03-28-2023 07:21 PM
Menu
3 down OK
down to bottom ok
left button ok
Good luck
03-28-2023 07:26 PM - edited 03-28-2023 07:33 PM
If only the printers menus are displaying in another language, you can use the following:
If the remote UI is also displaying in another language this one.
You do not need to reset the printer, just select the desired language. See page 380 if you'd like to take a look.
imageCLASS MF269dw / MF267dw / MF264dw / MF269dw VP User's Guide (c-wss.com)
04-05-2023 09:38 PM
I cannot change it back to English no matter what I do ... Brand new printer .. will now cost me $50 to fix it!! THIS IS INSANE!!
04-05-2023 09:39 PM
Danny ... what you suggest DID NOT WORK!!! I have to get a Technician to fix this brand new printer and it will cost me a Service call ... what's up with that!!???
04-05-2023 09:40 PM
NO .. this does not work ... tried several. times. What pin??
04-05-2023 09:41 PM
Does anyone has a viable solution to fix this Chinese language issue? What you are all suggesting does not seem to work in my world ... before I have to pay for a service call .. thank you to anyone who has a good suggestion!!
04-18-2023 10:27 AM
I have this same issue. My printer is also brand new. Is there a fix?
