ImageClass MF216N Printer Will Print But Won't Scan
SauderHH
I am having some issues with a MF216N printer. It is connected via USB to a Windows 11 desktop and will scan just fine. However when I attempt to scan something and select computer it displays "Connect the Computer". I did notice under the printer it says "Driver is Unavailable".
Things I have tried:
1) I have manually downloaded the latest driver UFR II/UFRII LT V4 Printer Driver V7.1.2 from
https://www.usa.canon.com/support/p/imageclass-mf216n?srsltid=AfmBOorMZu8Mm_Mpaq4VA-BABpUEEeyQ7pY4Ca...
and installed it through the wizard, but the error persists. The driver listed under printer properties is Canon UFR II B/W Class Driver.
2) Using a different USB cable and USB port
3) Removing and Adding the printer again
1 REPLY 1
PCW
I'm in the same boat with the same printer, except I'm going via the network. Any success on your side?
Paul
