10-25-2023
08:35 AM
11:04 AM
James_C
My MF264dwII stopped doing anything, and its menu screen is illuminated but blank, except for some differently-shaded rectangles (there is no text). When I try to access its remote UI from a browser, I get "The connection has timed out". I have tried unplugging and replugging it. The power button does cause the menu screen to light up and turn off. Turning it on, I hear healthy-sounding churning, but other than that, I can't seem to do anything with it in this state.
Is there a way to reset it?
01-10-2024 03:13 PM
Hello,
It looks like the printer may need service. If nothing is showing on the display and the printer doe not respond to any button presses, you can try unplugging the printer from the power and then pressing the power button 10 times while the printer is unplugged. After that, you can plug the printer into a different power source and you can try turning it on.
If the printer still does not respond when it turns back on, it looks like the printer needs service. You can check your available service options by logging into your MyCanon account or contacting support over the phone at 1-800-652-2666.
03-20-2025 10:12 AM
Hi there,
Was this resolved? My MF635cx is doing the same. This happened when I tried to install an update.
03-20-2025 10:14 AM
Hi, KSTR! As this thread deals with a different model, we recommend that you start a new thread for your inquiry. Thanks!
